Hello took my 08 jku out first time climbing and playin in the mud .I Had not even got out of the field put it in 4 high and it would not shift out of 4 high everyone said the linkage bushings broke got new bushings but I can not get the transfer case shift nob off I have pulled on it like crazy it will not budge any advise would be great
Does the lever move but it doesn't shift? Or does the lever not move?
This ^^
If the lever is moving easily, it could be the linkage that you can reach from underneath the keep. I had the little plastic piece that connects the shift linkage to the transfer case break
Reactions: FLEX B
I usually use a ratchet strap around the knob and the sound bar. Tighten up the strap and then start cranking on the ratchet. The knob will come off.
Discussion Starter #8
Thanks everyone it was the bushings they were gone no trace of them bought 2 new bushings for 9$ a piece put on both ends of linkage works great thanks again
