Just installed new adjustable swaybar links on my 98 TJ. I installed per instructions and set the drivers side link and installed. When I went to the passenger side, the mounting hole is about 1-1/4" off. (swaybar is lower than the link bolt hole)
Both links measure the same distance center to center.
I pried up on the swaybar, and installed the bolt.
Is this the right way to do it? Or do I set one side, and adjust the other side where the hole lines up, regardless of the measurement?
