I installed the Teraflex 2.5" lift and pro comp 35x12.5x17r tires on my 2013 Rubicon. Now whenever I flex the rear tires even a little bit I get a rubbing in the rear in the rock rails themselves as well as the metal behind the rock rail. If I remove the rock rails, the metal behind the rock rails will still be there and will rub. I'm assuming I just have to cut this.
Anyone run into this?
If so, what were your solutions?
