1 - 20 of 57 Posts
V2 should be much more exciting than V1 as I have learned a lot, I have much better tools and I am trying some new things... ;)
Goals
LOUD, but still maintain a high level of sound quality
Configuration
Active 3way up front and one sub in the trunk
Budget
Max $10,000
Components
Signal - Fiio X5 digital audio player
Amps - Mmats Hifi6150 & M2000.2 (150 watts rms to each speaker and 2,000 rms to the sub @ 2ohm)
Processor - MiniDSP 8x12 with DIRAC LIVE
Speakers - AudioFrog GB10s, GB25s, GB60s (this might change depending on fit)
Subwoofer - Hutchinson Audio NDFEB 1 -10" (1 ohm DVC, 2,000 watt rms handling)
Connections
Stinger 9000 RCAs
Stinger Pro speaker wire
Stinger Pro power wire
Sound Deadening
Soundskins & Stinger RoadKill
Fabrication
Ported sub box built and tuned to spec
Modified Metra dash pod to fit 6.5"s
Amp rack & lighting in the trunk
Dash insert for mids & tweeters
The Jeep
The Equipment
following
Reactions: DavidRam
I forgot to mention, the amps and the sub are handmade in the USA! To the extent possible, I am trying to buy equipment that isn't made in China, and IS preferably made here. That is one of the reasons I am not 100% on using the AudioFrogs, and I am still looking at other speakers that would work in this build...
I might go with Morels that are handmade in Israel.
Goals
Configuration
Budget
Max $10,000
Components
Connections
Stinger 9000 RCAs
Sound Deadening
Fabrication
The Jeep
The Equipment
Looking forward to see how this build comes out. What head unit are you going with?
I have the concept and design for the sub box mostly figured out... I just need to narrow down the exact dimensions and port size and tune.
Here is my first rough sketch where I threw my idea on "paper"
A little bit better of a description
I'll add some detail to the body of the box, by making it in separate panels, and then carpet and tuck them before assembly... The sideways L shaped panel gap will have a strip of aluminum bent and pushed in between them to sorta outline the box and bring more attention to the fact that it is cantilevered-ish.
The support on the hanging side will come from 2 aluminum legs that will be bolted to the body of the Jeep, but they won't be visible at first glance.
Discussion Starter · #11 ·
Drawing out the amp rack...
0 gauge from the battery to a distribution block and then 4 gauge to each amp. Only OFC, Knukonceptz Kolossus wire will do. ;)
I decided to run the power wire under the Jeep (on the outside), rather than through the interior and it will enter through a hole in the plastic tub.
any new progress to share? would like to see the exterior power lines.
Discussion Starter · #13 ·
I haven't run the power/ground cables yet... Still gathering equipment and checking fitment.
The Morel Elate mids dropped into the dash as if they were made for it:
The Morel supplied tweeter pods also look great and will mount to the factory grill:
I also got the Metra pods and the 6.5" almost fits... I'll do to a little trimming and then make a baffle for it. The pod will be vented with an aperiodic vent.
Going to be a great build.... Good luck and have fun as if it would be possible to not....:)
You'll have to excuse me... I didn't recognize your avatar on here. I'm used to seeing a different one on DIYMA.
Looking forward to seeing more of your build. :cool:
I threw some Hertz 3.5's in the front and back, but it almost feels like a step backwards. Mids/highs are clear, but because they are more efficient and 4 ohm drivers, they dominate the 4" drivers and don't blend worth a damn. Gonna have to do something different to make it work.
Mark
Discussion Starter · #17 ·
Mark
Haha, yep that's my avatar on audio forums...
I imagine those 4" dash pods will always be the weakest link. I am going to leave the soundbar alone this time around (I put rear fill in there in my JK) and really focus on making a really strong 3way front stage.
Hey buddy, trying to follow you but can't find the follow feature? Help an idiot out here, where is it?
1 - 20 of 57 Posts
