Hi everyone,
My JLU Sahara 2020 Engine 2.0 Turbo show bellow DTC errors after a engine maintenance.
Anyone have the service repair manual to check it, and help me please?
P012A turbocharger/supercharger inlet pressure sensor 1 - active
P006D barometric pressure - inlet air pressure correlation - active
P012A turbocharger/supercharger inlet pressure sensor 1 - pending
P0365 camshaft position sensor circuit - bank 1 sensor 2 - pending
P006D barometric pressure - inlet air pressure correlation -pending
Errors readed by ODB JScan,
Thanks Guys,
JLU MW from Brazil,
What type of engine maintenance was done to it? It sounds like there might be a connector that is not plugged back in all the way or someone bent a pin plugging something back together. You might start by closely examining any connectors and seeing if they are fully seated. If someone else did the engine maintenance I would drive it back to them and tell them to fix their mistake because it was not doing this when you dropped it off for the repair.
