I read that the JT has more aggressive fan blades and also a higher amp motor. So I was wondering would they work in the JK? The increased airflow should help in keeping th coolant temp down. Would this work? Are the mounting points the same? Will the height amp draw fry the TIPM? Are the even compatible? Thoughts
From what I understand about the JT, they also redesigned the grill to allow more airflow. Not just increased the fan size and capacity. They both need to be designed around each other. Putting a larger fan on the JK grill wouldn't move any more air if it is already moving maximum capacity. All it would do is draw more amps. The amount of air you can theoretically pull across the JK condenser is fixed, and its less than the JT condenser/rad.
