1 - 17 of 17 Posts
Picked up a 1999 hardtop last weekend. It was faded so today I painted it with Kryon Fusion Satin Black. I also painted the inside since it was white. Turned out great and I'm pretty happy with it.
I'm hoping the paint holds up against the UV. Has anyone painted theirs and how is it holding up.
BTW it took 7 cans to do both the inside and outside if anyone is interested.
I used Krylon on my flares the summer before last. It faded a little bit but still looks better than the gray that is used to be. I'm not sure how much hardtops fade since I don't have one. The rustoleoum bedliner I used on my bumpers seem to be holding up to UV better so the next time I paint my flares I'll use that instead.
i need to paint mine also. did the paint come out even using the rattle cans? Did u ever order your rear glass? if so how was the fit?
I did mine 3 years ago with fusion and it is holding fine. It has faded a little. There is a difference when I went to touch up a spot and it is darker with the new paint. Now my top is only on in the winter.
The only area you can see the spray lines is on the top section but no one is seeing up there.
Okay, here are the pictures:
Discussion Starter · #11 ·
No spray lines. I overlapped each by 50% and it turned out good.
I found the glass back in Indiana. My Dad is getting it today and I will bring it over here in April when I return from my travels.
The top cost me $320, rear glass $175 and paint another $50. Spray paint is $8 a can over here. :banghead:
Looks great. I'm planning on doing mine as well come Spring. Any issues with painting the inside black? I only ask because more than a few people have told me it makes the inside of the jeep like a cave. I'm hoping not because I really like the way yours turned out.
Discussion Starter · #14 ·
It's not too dark. My soft top was dark too.
I did it cause inside I already have red, black and tan. Adding white just made it look odd. Now the top matches the floor.
Looks fantastic! :thumb:
Come spring time when the hardtop will be replaced with my beat up softtop I plan of doing the same thing... Quick question. How many cans did it take to do the outside only? I know you said 8 for the whole thing but could you estimate what it was for just the exterior?
Also, did you sand and prep it in anyway, or just mask off the windows and paint? Did you paint the vents too? Just curious since I'm grabbing info for my own plans...
BTW, that top still looks great! I'd love for my faded hardtop to look as good! :D
Discussion Starter · #17 ·
Looks great my LJ top is grey I want to paint it black so thanks for the info.
Mine was gray too. It needed paint.
I used 4 cans for the outside and 3 inside. Eight cans would be perfect.
I scuffed the surface with a green scotchbrite pad and wiped it clean with acetone.
1 - 17 of 17 Posts
