Bought the A pillar switch pod and I want to move the switch to the new switch pod but the switch that's already there doesn't have a ground
On the rocker switch it needs a ground.
What should I do ? Can I just buy a wire and make it as a ground ?
Usually if the switch is lighted (illuminate when turn on) it will require a ground. If the switch is not lighted you don't need a ground.
☞Sent from here☜
I just re-read your post. If you need a ground fir the switch yes just run a wire from the ground post on the switch to a grounding point (usually an existing bolt work fine)
☞Sent from here☜
