1 - 15 of 15 Posts
I'm having big issues with my keyless entry. I have to be within 5 feet of my Jeep to lock/unlock/remote start with the key fob.
Changed batteries twice. Any solutions? When I got the Jeep in March I could be across the parking lot with no problems
Same here. Buddy and I walking back to our vehicles. My JK he had his wife's dodge mini van. He points his key fob as soon as we saw them. His opened I had the walk quite away before mine would open. His is older than mine. Mine is 5 months old. Must be where they hide the antenna.
My JK's fob works at quite a distance, from standing outside or in. I'd warranty it it if truly becomes a problem.
I've got a '13 JK and I just tried it. I can see my Jeep in the parking lot and my fob works from at least 100' away when I am inside my office I can click the fob and the lights flash.
Lotrat said:
Hold the fob to your chin for max distance. You'll get another 10-20 feet.
They showed that on Top Gear UK
I bet my range under 20 feet. What's odd is that I had the same exact key-fob on my 2005 Dodge Magnum and the range was probably closer to 150 feet.
i think height is key (no pun intended). My range is terrible while walking to my jeep in parking lots. But, i did have it work 300feet away, while i was looking out a 3 story window @work.
Mine not only has poor range, but sometimes I have to push the buttons multiple times to get the doors to lock or unlock.
I found that my range varied somewhat, between poor and terrible, depending on if I was facing the front of the Jeep or the rear. Still wasn't happy with it regardless, and ended up going to a quality aftermarket alarm/remote start with 2 way communication, installed by a reputable auto electronic shop.
My remote start button has incredible range (hundreds of feet), but for my lock/unlock buttons to work I have to be within 50 feet.
Discussion Starter #14
SouthTJ said:
Have you installed anything that could interfere with the antenna on the wireless control module?
I've installed a Uconnect system & new speakers; this is all I can think of that may affect electronics. I have no idea if these things limit the functioning of my module.
I'm just disappointed in the performance now compared to when I purchased it. FWIW, its a 2008, bought used, obviously.
dirt road inspector
Same here with maybe a little less range on both. The lockers are finicky. Have to press them multiple times.
1 - 15 of 15 Posts
