1 - 20 of 23 Posts
i have the same problem, and not only is the key stuck in, but the tumbler has a lot of resistance going to start and on... so much so that the key will stick in the "start" position and keep turning the starter unless i manually pull the key back to "on" myself
HELP PLEEEEEEEEEEASE!
I would say if it is a regular switch and they didn't put any kind of pass-lock on them in the newer models then just go to the nearest auto parts store and buy a key and tumbler switch set for around $22 and replace the switch.It comes with two keys and if it is like the other models can be changed in about 20-30 mins.Now here is the bad part if you don't do it now and hold off until you can no longer turn your switch to the ON position it will take you about 2 hours to change because the switch has to be in the on position before you can push the locking pin in to remove the old switch.So do it now before you have to drill out the tumblers and turn it to ON with a screw driver.;)
my cherokee used ot do this, we had to shift threw the gears and play witht he key and it eventually worked..weird
try pressing down hard on the brake...this happened to me once or twice and by doing that I somehow got some electrical switch to engage so as to free the key.
works like a charm :punk:
i actually found out that i have a habit of keeping my foot on the break while turning the key off... weird i know, but yeah. works fine now.
Key stuck in ignition: Just happened to my daughter (1999 Sport, Auto Trans). I read on other places on the Web that if you reach up under the steering column and wiggle the wires and cables there the key will release. It worked.
Mine did this a while back and the key wouldn't turn either.
I had to get a new tumbler. I think it was a result of simply hopping in the Jeep and just shoving the key in quickly and turning it to crank it at almost the same time.
Now I take my time when inserting the key.
I am having a similar issue - it appears as if the lock release button is stuck in. This would usually pop out a bit when key is inserted. I've read posts on changing the tumbler unit but I don't think that is my issue as the button to release the key seems to be a separate part.
Banned
Welcome to the Forum.
1 - 20 of 23 Posts
