A few days I plastidip'd my keyfob, having removed all the internal parts prior of course. Everything worked fine. Then I got a little carried away, but don't ask how, but the bottom part of the circuit board got a little chewed up, but not bad. The inside of the plastic where the key is embedded in the plastic is a little chewed up too. Still worked! Today I went to start my Jeep and it turns on, and 3 seconds later, turns off. The red light above the temp gauge stays on. I reset the IOD fuse and removed the negative battery terminal and reset everything, but the same issue. The remote works fine. All the buttons; lock, unlock, remote start and panic all work. But it's like the key isn't being recognized as a valid key. Even when I use the remote start, the moment I put the key in, it turns off. Any ideas? I thought at first it was the control module going bad but its a little coincidental that all this is happening around the same time I had it apart and messing with it.
