Taken off of a Jeep after 5k miles to go coil-over, was going to put them on my Jeep, but I'm going to 4" coils, these are too short for me. In great shape with Compression Adjusters, comes with rear upper bar pin eliminators and optional aluminum resi clamps. Great upgrade if you are running a leveling kit or the Mopar 2" lift kit or equivalent
Over $1,800 new...$1,350 obo
King Part Numbers Collapsed Extended
25001-180 Jeep JK 07 + 0-2" Lift Front Shocks 15.831" 25.902"
25001-181 Jeep JK 07 + 0-2" Lift Rear Shocks 16.188" 26.28"
King's new line of Original equipment manufacturer, (OEM), shock upgrade kits provide a bolt on suspension system that elevates your on and off-road performance to unmatched levels. Each kit has been subjected to punishing real world testing to develop the optimal damping curves and spring rates for your vehicle. Built with the same quality of materials and precise tolerances found on King's high end race shocks these OEM upgrade kits enable you to experience the famous King ride quality on your daily driver or prerunner. Built with race winning design features our kits come complete and provide simple 100% bolt on installation with no cutting or welding done to your vehicle. Large 2.5" diameter shock bodies with external reservoirs dramatically increase fluid capacity and heat dissipation to provide sustained damping performance even under the most punishing conditions. These Shocks include the Wide Range Compression Adjuster that offers 20 positive clicks of precision adjustment from very soft to very firm. The ergonomically designed and clearly marked billet knob makes adjustments quick and easy. These OEM upgrade shocks feature the same serviceable design that allows for valve adjustments with simple hand tools just like King's race shocks.
pics
bump
