1 - 20 of 48 Posts
Ive seen alot of people on here say its most likley the throw out bearing. My question is, shall I make priority to fix it or not? How long could it be like that? Is it detrimental to my jeeps' overall health?
Does it disappear when you push in the clutch? I've had that problem forever. I've change out the clutch and all bearings when i had to and the sound is still there. figured it was just a jeep thing.
· Knows a couple things...
2004 Wrangler TJ, 42RLE auto trans. F/R lockers, 5.38 gears, Warn Winch, Currie 4" Suspension
A knocking sound is not normal but a spinning bearing sound that goes away when you step on the clutch pedal is 100% normal.
And if it might help, it started doing it after being put under some pressure. I was stuck in an akward position, in the process of geting pulled out I noticed that. And I had some oil come out of my rear main seal if im not mistaken, ive cleaned the area and theres no permanent leak. So I just changed the oil.
I have the same issue, and have had it for about a thousand miles, foot off the clutch (engaged) rattle, foot on the clutch (disengaged) no rattle. It's the throw out bearing spinning and it is just worn out, something to eventually be done, but it's not going to stop working for a little while. If you get the chance to do it, I would, but I wouldn't fret over it, unless of course you've been driving on it for 10 thousand miles lol
You have it a little back asswards there, throw-out bearing should only make noise when the clutch is depressed, as that is when the bearing is spinning. Otherwise it is disengaged.
You are correct to a point, the throw out bearing is still spinning regardless of its position. They can make noise either way depending on which portion of the bearing is bad. They can rattle at rest, or they can grind/ whir when the pedal is pushed.
The bearing does not spin when the clutch is engaged, it only spins up when depressed.
It could be something as minor as a broken clutch return spring in the bell housing, in which case, it's just more annoying than anything else. If that's what it is, it won't hurt anything. Watch the last few minutes of this video.
https://www.youtube.com/watch?v=mIXhdAG3qaE
That spring is there to hold the clutch arm on the pivot arm untill the tranny has been stabbed, it isn't a return spring.
The pressure of the slave cyclinder rod keeps constant pressure on the pivot side and the throwout bearing is turning the whole time the motor is running.
· Mostly old school..!
You probably should go ahead and let Chrysler know that they are wrong and used the wrong terminology in the FSM. The fact is, that it is a return spring and if you have the transmission out sitting on the floor and pull the throw out arm forward, the spring will in fact pull the arm back when you release. If the slave cylinder maintained pressure on the throwout arm to keep the opposite end against the ball, it would also force the throwout bearing to constantly ride on the pressure plate, which it doesn't.
Discussion Starter · #18 ·
Ive watched the video and it makes perfect sense, I beleive im ready to diagnose. Now the question is, is it a must fix asap kind of problem? Or can it run like that? Thanks for the vid recomendation, and help Water Dog.
If that is in fact the problem, it won't hurt a thing to run it like that. The spinning pressure plate will keep the throw out bearing thrown off, it's mostly just the noise you'll have to live with. Typically the noise that is associated with a broken return spring is kind of a rattle...not sure if that is what you have or not.
1 - 20 of 48 Posts
