41 - 48 of 48 Posts
Are you quizzing me?
Yes
Whammm they are bolts. Not studs with nuts. Unless you were referring to me. :) I have a 2000 as well really starting to doubt where you get this stuff.
They are studs on all the Jeeps I have seen, you must have a special Jeep, post a picture of it.
As far you calling names, I'm not the one that let a dealership put a plastic throwout bearing on my Jeep.
· Knows a couple things...
2004 Wrangler TJ, 42RLE auto trans. F/R lockers, 5.38 gears, Warn Winch, Currie 4" Suspension
If you're looking for instruction on how the throwout bearing works, fine, let us know & we/I can help you out on that. But if you want to test my knowledge, don't bother since I know how the clutch and the throwout bearing works. I did my first clutch job in '68, likely before you were born.
And if you're going to continue busting people's chops on such critical topics like whether it's a bolt or stud that holds the slave cylinder in place, and it is indeed a stud but even you first described them as bolts in post #31, I'd find a different forum that may enjoy that type of attitude better.
41 - 48 of 48 Posts
