1 - 20 of 23 Posts
Elite 30" Dual Row
Looking to turn night into day? Looking for the best of the best? Look no further than the KOR LED Elite Series. The Elite Series is designed not to skip on any details. Elite Series LED's have been torture tested to ensure the highest quality LED Light possible. With a life span of over 5+ years (50,000+ hours) of continuous use, the Elite Series LED Lights will not leave you in the dark!
Each Elite Series LED Light comes ready to install so there is NO need to buy a extra harness. The Elite Series comes with its own high quality harness with the correct fuse, relay, and switch. The harness has a waterproof connector for easy installation. Each Elite Series LED Light also comes with its own standard mounting brackets although custom brackets may be needed for you application.
Also unique to our Elite Series is the breather port. Adapted from Military applications, the breather ports allow our LED Light to "expand" and "breath" through different operating temperatures. These ports also allow for the expansion and contraction of the housing and helps protect the waterproof seals. Long story short, it extends the lift of the LED Light and keeps it watertight!
Specifications:
Size: 30" Dual Row
LED QTY & Wattage: 60PCS & 300W
Lumens: 16,800LM @ 12.7A
Voltage Range: 9-36V
Beam: Combination Flood/Spot
Lens: GE Lexan Lens
Housing: Aluminum
Warranty: 2 Years
Elite 2x2 Cubes, Pair
Specifications:
LED QTY & Wattage: 4PCS & 20W
Lumens: 2,200LM @ 1A
Beam: Flood or Spot
Lens: GE Lexan Lens
Housing: Aluminum
Warranty: 2 Years
Elite 50" Single Row
Specifications:
Size: 50" Single Row
LED QTY & Wattage: 50PCS & 250W
Lumens: 27,060LM @ 17.3A
Lens: GE Lexan Lens
Housing: Aluminum
Warranty: 2 Years
Call, Email or PM us today on any KOR LEDS you need! We wont keep you in the dark!
Austin
Discussion Starter #9
Discussion Starter #12
Discussion Starter #13
Discussion Starter #14
Chris May running our KOR LED's in the King of the Hammers.
If they can hold up in that race they can withstand anything!
Call, email, or PM us today on your next set of LED's
What hes running
50" LED Light Bar
https://www.krawloff-road.com/product_p/kor-e50dr.htm
3x2 LED Driving Cubes
https://www.krawloff-road.com/produc...r-e3x2-d-p.htm
Specifications:
Lens: GE Lexan Lens
Housing: Aluminum
Warranty: 2 Years
Discussion Starter #15
Discussion Starter #16
Discussion Starter #17
Discussion Starter #18
Discussion Starter #19
Discussion Starter #20
Elite 30" Dual Row
Specifications:
Size: 30" Dual Row
Lens: GE Lexan Lens
Housing: Aluminum
Warranty: 2 Years
Specifications:
Beam: Flood or Spot
Lens: GE Lexan Lens
Housing: Aluminum
Warranty: 2 Years
Specifications:
Lens: GE Lexan Lens
Housing: Aluminum
Warranty: 2 Years
Austin
1 - 20 of 23 Posts
