Hey guys I'm trying get some more lift for my 93 yj I got longer shackles buy I want to do the add a leaf . Does any one know how much lift that would give me and what if I got a leaf spring from a junk yard what type of vvehical should I get it from and what order would I put them in
Personally, I dont like them...
But depending on what you buy, will depend on your lift. I suspect anywhere from 1" to 2" typically.
In my opinion, buy a leaf with the eyelets, cut the eyelets in half, then install it under your main leaf so the cut eyelets help support at the shackles and the frame connection. That way your not stressing old leafs as much as an add a leaf would. I have seen old leafs get bent at the point of contact with the add a leaf.
I'm with camarozz on this one. You're better off with the leaf with eyelets per his instruction.
Denis
