Ok... Let me try and explain this.
I am replacing my front CA/Tb bolts with the synergy kit.
Front track bar bolts are replaced and still loose.
Driver lower control arm bolts replaced but still loose.
Now.... I went to loosen the passer lower control arm and it was sorta bound up.
Removing the bolt the axle sprung forward about 1/8
I am still running stock uppers. Recently I adjusted my lowers for a better pinion angle with my Adams DS.
I tried to set both to the same length or maybe a turn more on the passenger side (crown in road)
The question- it seems like the axle was bound up and when removing that control arm wanted to go to that new location. Should I adjust that arm to match that hole or bring it back in.
I should be saying "rotate" but you know what I mean
Thanks
Thanks
