LDP 04 tj?
2644 7
An anyone tell me where the leak detection pump is on an 01 Tj? I'm getting a p1494 code. I just had to lower the gas tank a little to get some work done. Could I have pulled something out above the tank?
Did you get the info? If not, it is in the right rear quarter panel area more or less in front of the tail light. Dropping the tank could definitely cause a hose to get pulled off somewhere, probably one between the tank & LDP.
From the FSM: The Leak Detection Pump (LDP) is attached to a bracket located to the rear of the right / rear tire under the plastic wheelhouse liner.
This might also help:
