1 - 15 of 15 Posts
You may want to repost on the JK discussion forum to get more responses. And add more specifics. I have a problem on my 09. There's a black foam piece at the corners that tends to leak. I used silicone and it worked on the passenger, but the driver side leaks like Niagra falls when it rains. I'll get it to the dealership to get replaced one of these days.
Yours could be something in the header channel.
If it's new, just take it back and get it fixed under the warranty.
I've got the same issues. 16 hardrock and its in the shop for the second time in a week. First it leaked above the radio and they fixed that. Now it's leaking at both a pillars. Very disappointed!!
The Jeep world is broken into two types of people. Those whose top leaks and those whose top will leak. Eventually they will all leak. The good news is that Jeep knows this and made the carpets with some anti-fungal coating. Nothing to be concerned about. Just take it back to the dealer and they'll fix it. My dealer has a leak specialist that comes twice a week. I've had a couple of leaks and they've been fantastic about fixing them. Don't sweat it and enjoy your Jeep.
Check to see that the door molding isn't bent or kinked at any point and make sure you close the door hard.
Never had a leaking problem with my '09. However, my '15 leaks bad on the passenger side. In a decent rain my passenger front floorboard will fill up with water. I pull the carpet up, remove the drain plug then head to the wash rack to vacuum up whatever else i can.
I've had my JKU for a few months now. I've found it wet on the front passenger side right against the door sill. I did find that the passenger side freedom panel roof screw down had managed to loosen itself to the point that it fell out. Hopefully that was the problem. I haven't found any leaks anwhere else. I did notice every time I open the door a whole lot of water drips down from the roof and door channels.
The freedom panel screw is most likely not the culprit, many here run without those screws intalled at all and don't have leaks.
The open door drips are just something every Jeep owner lives with, it's comes with the territory. There is nothing you can do about those drips.
I'm also experiencing a small leak on the driver side in between the door and windshield. I can't figure out where it's coming from, but on days when it rains heavily then water will trickle down the A-pillar and into the carpet.
That's the door moulding, that is where the majority of people get their leaks....including me. My dealer replaced the door seals and re-aligned the door so the top corner is pushed in a bit so the water actually runs into the door seal water channel as it's supposed to. The reason many leak is the door is mounted too far out away from the A pillar thus allowing roof run off water to get behind the door seal channel it's supposed to flow into. Once it gets behind that channel, it can only go one way, inward eventually onto your front carpet(s). The only downside to the door alignment is now my door is really hard to shut properly when the hard top is installed since it's really airtight.
I just don't get why they can't redesign the rubber door moulding to make that water channel inherently press up farther and tighter to the A pillar top corner, that would solve 90% of the door leak problems.
I've had my Jeep parked outside in more rain the last week than in the entire time I've owned it. And I noticed that it is leaking at the bottom of both front doors onto the front floor mats. The driver's side has a steady stream coming in at the bottom of the door to the front of the plastic door sill protector; this stream flows downward onto the carpet. Same on the passenger side just not as much. Appears to be coming from the front top of the doors at the windshield/roof junction and traveling down between the door and the body and then into the cabin at the bottom of the door where it meets the sill protector.
I wonder if the dealer will blame it on the Mopar sill protectors.......
I had aftermarket door sill protectors and ripped them back out after about a week. I could tell the were there, it took slightly more force to shut the doors. I was installing new speakers in the sound bar, and when in the back of my Jeep, I noticed all the light coming in from under the doors.
Took mine in today for leaks. Dealer told me there is a TSB for Leaky roofs and they ordered all new seals for me, hoping that takes care of it
See my post above. Your water has nothing to do with the door sills, it's the door alignment and moulding in the top corner as you stated. If your dealer is worth a salt, they'll know that.
I agree. I just sprayed the top with a garden hose set to "Shower" and within 30 seconds had water running down the inside of the door seal:
1 - 15 of 15 Posts
