Hello -
I have a Softopper that is at least 5 years old, maybe longer. For the most part its in good shape and functions quite well considering its age. It does leak a little bit and that is what I'm trying to figure out. It rained pretty good here this morning so I was able to get in and capture where it was coming in from. It was dripping from the two flaps on either side of the doors. After closer inspection it seems like it is coming from the top and wicking in and then dripping. I did just replace both door seals. The inside seals seem to be dry. I've attached some photos to help better explain.
Thanks!
Thanks!
