Swapping emergency flasher relay for turn signal flasher relay,thats all it took to get them to flash. Who knew? Not me,for a couple of hrs anyway.
When i wired led lights up ,everything worked,but blinkers wouldnt blink they just lit up. All the forums said i needed a elec flasher relay. I tried swapping the two relays above fuse box and now everything works. Dont know why but it does,even emergency flashers.
Suprised the swap worked for you, I tried the switch too, but alas had to go fetch an electronic flasher relay to get em to work,
Yeah mine worked by just swapping the two as well, at least for a day or two. Then they quit. I still wound up buying an electronic flasher. Good Luck.
