I was looking into replacing my stock headlight bulbs with LED from headlight revolution they told me I would need to install the anti flicker module since I have the 2.0 engine but with the 3.6 the anti flicker module would not be required has anyone with a 2.0 upgraded their bulbs to LED?
Ed
I'm not sure about the 2.0 anti flicker requirement, but on the 3.6 these bulbs below work plug & play perfectly without flicker. You could try something like this and add the anti flicker module only if needed.
TECHMAX Mini H13 LED Headlight Bulbs,60W 10000Lm 4700Lux 6500K Cool White Extremely Bright 30mm Heatsink Base CREE Chips 9008 Hi/Lo Conversion Kit(of 2) https://www.amazon.com/dp/B07CBPV3WW/ref=cm_sw_r_cp_taa_AvbxDb1BVF75T
