He front turn signal bulbs are 3157 and I want to change them to led switch backs would the led bulbs work or would I need to starting changing other stuff also 2013 jeep wrangler
ExtremeTerrain.com Sponsoring Vendor
There are BUS safe LEDs that you can get which should work seamlessly with your Jeep. Here is an example of one I found. That was just a quick search so double check that before you purchase. That site has good customer service so you can call them and check as well. Let me know if you have other questions!
-Ryan
