So I went to the local junkyard and picked up 3 15" led lights, come to find out there flashers.( like on a volunteers firefighters vehicle) My question is, is there a way to make them not flash, and just run constant?
2footin is correct, if there are three wires or more on the lights, you probably have a light with selectable patterns; often times one of those patterns is steady burn. If it's a three wire setup than you usually need to pulse the third wire with a ground or positive signal while the light is powered up with the other two wires.
