1 - 9 of 9 Posts
I have developed a problem with my 90 YJ. When I turn left sharply at speed the engine dies. Then it coasts for a bit and the engine refires and runs normally. The only thing I can see is that a small hose running from what appears to be a small filter connected to a wire on the left side of the engine near the starter is not connected to anything and I cannot find where it connects. Please help. (Left side facing rear).
Crankshaft position sensor?
How much fuel do you have in your tank when it happens. Mine does this when I'm low on fuel, never an issue with a full tank for me. I haven't dropped my tank yet to find the issue. Just an idea.
^ yup this is the most annoying thing on my '90
Yep, if your low on gas, when you turn left at a decent speed it'll stall. Just keep gas in the tank and I bet you'll be fine
Thanks to everyone who said put gas in it. Filled the tank and problem went away. Found the tube went to the 4 wheel drive sensor.
hey i have an 89 2.5l that does the same due to being a ff and work long distance does any one know how to fix that issue it is a new tank before i bought it any info on this would help
1 - 9 of 9 Posts
