Well its time to start spending some money! :dance:
Just picked up an 08 unlimited last night completely stock. I have been doing some research on here for awhile but still have a few questions. Also I am looking for any information that could be useful in my future.
First thing I plan on doing is wheels and tires. I would like to go with a 285 or 295 70 17. I have been looking at pics, but it is hard to tell if they will be wide enough for me, I hate the narrow tire look. I'm looking at the Nitto grapplers. I will be getting the the XD Addicts 17x9 in black. Would you go with 285, 295, or bigger?
Also, can I run 33s with stock height? I plan on putting on a terraflex 3 in lift, so should I wait for the lift if I want to run that tire size? I have done most my research on the 2 door since I planned on getting one of those but came across a good deal and couldn't pass it up.
Those are the first two things I plan on doing. I have a whole list of mods to come but will worry about those when the time comes.
Jk can handle the 33 without a lift as a daily driver and light offroading. It will rub on trails were articulation comes into play. You can get by on light offroading and only need a small lift before hitting harder trails.
As for 285 vs 295. Most go with the 285's because there isn't a lot of difference and the 285's being a more common tire are usually quiet a bit cheaper.
Supporting Member
Which grapplers? Mud, Trail, Terra? Any way a 3" lift IMO will be overkill for 33's, as Daggo said no lift is really needed for 33" tires. It's your Jeep and do what you plan on doing, but I had 33's Maxxis Bighorns and sold them to get 35's. I would reccomend a 2.5" lift and if you ever wanted to upgrade to 35's you could still fit them.
-Dan
Discussion Starter #6
The Terra Grapplers.
Thanks for the info guys. Would a half inch make that big of difference?
