1 - 20 of 63 Posts
I've been seeing more aluminum aftermarket parts lately for weight savings. I like the idea.
I don't really care about MPG but I know heavy bumpers/armor sag the suspension and have a negative impact on braking, handling and acceleration. I know, I know, braking and handling aren't exactly Wrangler strengths. But why make it worse if avoidable.
I love the Rampage front recovery bumper but 130 lbs! I'm sure it's tough as nails but man, all that weight hanging off the front even before a winch.
I was looking at the Rockhard 4x4 aluminum front bumper w/ winch mount. I wondered if anyone has installed one and if they had any feedback? I searched but couldn't find anything.
Pros: weight; won't rust (I'm in Wisconsin - lots of salt in winter); stronger than stock plastic bumper.
Cons: cost $$; not as strong as steel
I noticed some aluminum skid plates too. Just curious what you all think about that vs. steel. I'm sure not as strong as steel but in the case of a plate to cover oil pan and manual transmission, it would be better than what's there now (no skid). Anyone have any experience?
Rock Hard 4X4 RH5005 - Rock Hard 4x4 Parts Full Width Front Bumper for 07-14 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
Rock Hard 4X4 RH6003 - Rock Hard 4x4 Parts Oil Pan, Transmission & Catalytic Converter Skid Plate for 07-14 Jeep® Wrangler & Wrangler Unlimited JK with Short Arm Suspension - Quadratec
The problem with aluminum is that it scratches more easily. Other than that strncht is the same depending on the thickness.
That bumper looks nice!
I'm more concerned that aluminum in general is weaker against fatigue than steel. If any part of the bumper flexes repeatedly, it's going to fall apart right there. If designed right, it should not be an issue, but it requires some attention.
Generally though it's the same as any bumper - you need to find someone gullible enough to buy it first, see what they say.
I would say it depends on your usage. If you gonna be bashing it into stuff all the time then go with steel skids and bumper. If its for looks and the occasional ooooopsss then you should be ok with aluminum. I have an aluminum River Raider oil pan skid, but I knew I wouldent be banging into it every weekend or anything its just there for the accidental stump or log covered in snow that I didnt see, so for me the advantages of aluminum prevailed.
A properly made/treated aluminum bumper can be just as strong as steel and can certainly deal with repeated flexing without any problems (ever seen how much flex there is in an aluminum boat.. or planes...?)
It all depends on what alloy they use, how the material is worked/handled and treated.
I'm not sure I'd want to be the first to bite though ;-)
Big problem with aluminum is it's just as strong as steel by weight. Heavily touted. An aluminum bumper the same SiZE as a steel one will be much weaker and lighter. An aluminum bumper the same strength as a steel one would be huge. Light but to big to be practical. Aluminum would make a crappy bumper.
The 'trick' with aluminum in an application like this is better engineering. It would require more gussets to keep the bulk down and the strength up. I'm sure one could engineer an aluminum bumper that's as strong as steel but not excessively bulky however it would cost more to build due to complexity.
Kaiser aluminum makes aluminum armor plating currently in use on Humvees, planes, etc. A lot has to due with the alloy and treatment, which again raises cost.
I doubt that anyone who's manufacturing bumpers for JK's is going much more than just swapping the materials used and hoping for the best.
EDIT: found the US mil spec for al armor plate. 1.5" of aluminum armor can stop a .50 cal AP round at 1955fps. Increases to 3" (roughly) at 3000fps. That's pretty impressive IMO.
Commodore, Great looking bumper. Don't be misled by anyone who doesn't understand the strength of aluminum. I have a background in metal fabrication and have used it in some extreme applications. I am also a retired Field Artillery Officer (Army) and can attest to the aluminum used in our weapon systems an battle ready equipment. Trust me.... we soldiers try to break everything we touch. LOL
I think the question is would bumper manufacturers use the proper alloys, heat treat and in general handle the material correctly. I have doubts about that.
I don't see any problem using aluminum for either bumpers or skids. Yes, there are design considerations, but it is a lot stronger than steel lb for lb and you can double the material thickness and still have something a third lighter than using steel.
I'm going to guess just about everything available in the aftermarket for Jeep use will either be 5052 or 6061 aluminum alloys, and both are easy to weld. For bumpers and skids, 6061 is quite a bit stronger but for fuel tanks 5052 is easier to bend up.
If you drive someplace where road salt is common, don't think aluminum doesn't corrode. It will pit very quickly if not protected with something.
McMaster-Carr has some good summary info:
McMaster-Carr
Would I use aluminum bumpers? You bet. I'm planning on an aluminum replacement for the rattle box Rock Slide Engineering steel version on my JK and already have all kinds of aluminum pieces my 3B.
Belly skid-6061
Exhaust skids-6061
Hood-5052
Filler garage-5052
Tire/door carrier-5052 and 6061
In short, the stuff will work just about anywhere if properly designed, will be stronger than steel, and lighter in weight-all the same attributes that make aluminum the near universal choice for aircraft material-at least before the arrival of carbon fiber. I'm a big believer in light is right. Especially in a Jeep, the lighter you can build them, the better they work off road, and you get a gift of better fuel economy in the process.
Genright has been using aluminum for years. Not sure why there is so much doubt here. The RH stuff looks new to me so they may still be learning what does and does not work... Their other stuff lives up to their name so i would not be overly concerned about quality.
Commodore, I called RH today and spoke with the owner. He is a solid dude and shared a ton of information. He said that almost half of his aluminum bumpers are being ordered with towing eyelets. That bumper is plenty strong. Pretty sure you will like it. Gonna order one myself now.
Was his name James? He is a professional in all aspects. Also has an awesome family, We have spent some time with them. Can't go wrong with RH.
HE = Rock Hard I presume? Nice to know there are good al bumpers being made.. going to have to add this to the list of maybe future stuff.
Discussion Starter · #15 ·
Really more for the occasional ooopps as you say.
Discussion Starter · #16 ·
Thanks everyone for the great responses! This has been on my mind and I knew I could count on WF members for some good thoughts. Hopefully others will find the thread useful too.
Im a huge fan of aluminum parts, especially on a jeep to minimize weight, but never on the front. The front is steel only for me. I want maximum strength. BTW, the Rampage bumper without winch and winch plate is only 85lbs, not 130. The protection of steel is worth it to me over aluminum.
Correct. Aluminum needs a lot of skill to make it effective, with bends, knurls, etc. As far as aluminum skids go, the only ones I have seen perform are the nemesis skids, but the price is insane.
1 - 20 of 63 Posts
