I have an 07 Wrangler Unlimited X that is mainly used to drive my son to baseball practice and me to work. I want to upgrade with a lift and tires that will help me get around my deer lease in the TX hill country. (Dirt roads that are rocky and sometimes muddy) I am not planning on doing any serious off-roading. So I need the best recommendation for something that will be a daily driver, get me around the lease, look cool, not break the bank, and is not complicated to install. Based on my limited research and knowledge I was thinking a 2" BB with 32" tires. Then I read somewhere that you shouldn't exceed 31" tires with a 2" BB. Also, I'm under the impression that with that setup I wouldn't need to do any more modifications than the BB. Is that true? Any help would be appreciated. I'm sure these are relatively dumb questions but I only know enough right now to mess up my vehicle. Thanks in advance.
Waddy
Head over to http://www.wranglerforum.com/f202/beginners-guide-to-lifting-your-jk-298665.html
kjkeeper10 has awesome advice, and is very active on these forums.
I put a simple Teraflex leveling kit in my 2015 JKU, which came with stock 32" tires. Obviously, I did not even need to do a lift with the stock tires. (This is the basically the same as your 2"BB pucks)
Now, a 2007, JK....unsure of the difference, and I could not imagine any (again, that link in the place to begin!)
Now, the cost of that lift alone could be the low $100's if you do the work yourself. It is not too hard, and watch many videos in detail. Having some of the right tools is important.
If you have a shop do it (which there is nothing wrong with that!), it will be around $400-$600 depending on your local shop prices.
You can run a 285x70r17 with no lift. You can run a 35 inch tire with a budget boost.
I was not happy with the flighty/darty steering of my rig with a budget boost (2.5").
Based on that, I would recommend front lower control arm relocation brackets, or, front lower control arms that allow for the caster correction.
A 2.5 BB is a great way to achieve your goals. Take a look at the Rough Country Series II budget boost. A fantastic little lift at a great price. In most cases, you need nothing else...
BUT, every Jeep is a little different and some do need caster correction even with a budget boost. It's an easy add on afterwards if you decide you need it. You will not hurt anything to build it without and see.
If you do need it, I recommend the TF Sport front fixed lower control arms.
Stock tires on all but the base models (some do or used to come with 29 inch) are 32 inches...zero lift needed. Problem solved. A level kit would give just a little lift if you want it.
