I need to pose a question to those who have lifted 2.5" (or less). Did you need front brake line extensions, or did you find stock length sufficient for the amount of new travel? Thanks!
I have heard the 2011 and 2012 front brake lines are shorter than previous years, you might want to add an extension bracket... If you plan on off roading.
I just did a 3.5 AEV lift on my JKU-R and it came with brackets plus I had to do some other modifications to extend the lines a little further.
I have an 08, so theoretically I should be OK, based on this.
