Lift kit for comfort and look, not wheeling
23524 264
Hey guys, first thing I wanna say, "I will not be wheeling this Jeep"
I have a 2005 2.4L se with a 6 speed manual. With just under 100k miles. It has the original suspension components, shocks, springs, control arms. I have 31x10.5 tires on 15'' rims right now. My next jeep will be my built wheeler. The key things I am looking for is a little bit of lift with comfort in mind. I have done plenty of research just looking for input from a few eyes of experience. I am not going any higher than 3" of lift. I am going all suspension, no body lift. I will be using motor mount lifts from Brown Dog Offroad so I can keep the driveline angles correct, and NOT doing a transfer case mount. It is not cost effective to get new shafts and a SYE. Since I will not be wheeling I am looking for 2-3'' springs and shocks. What other components/brands would you guys recommend for a basic lift like mine. More geared towards comfort than performance. I do not want super stiff springs as I have the 4cyl and don't have a whole lot of weight. Feel free to chime in. Thanks for the time.
1 - 20 of 265 Posts
Also keep in mind all jeeps are different. I put 2" lifted coils on my jeep and added the brown dog 1" MML and still needed near a 1" TC drop. The angles don't lie and mine needed it. I'm not saying yours will need this but all jeeps are different. I have 2" four wheel drive hardware coils and bilstein 5100 shocks. The ride is very comfortable on and offroad.
Swap it out for a low rider S-10 and sell the Jeep to someone that will use it :)
Ok man. Haha. That's funny. Not everyone uses their jeep to climb a mountain. If you are not going to contribute, please leave the thread. I'm looking for actual advice, not a cynical closed minded comment.
Okies I would just use some spring spacers like teraflex and daystar sell, sure there are a ton more. Gain an inch or more and have the exact same ride quality. If you go into 3 inches with just springs you may have some vibe issues, My 3 inch teraflex lift came with a T case lowering kit. Its available separate so If you want to take it up to 3 inches go with springs and a lowering kit. It will make your jeep handle worse around turns. I love my lift but hate when those highway signs say slow down for a turn and I better fing do it! You could do so much cooler stuff to your Jeep to make it a head turner and keep it handling best for your intended purpose if you left the suspension stock.
Majnoon, I was looking toward a slight lift with springs and shocks just cuz the stock is nearing the end of its life and rather than replace with stock or do a body lift I might as well lean towards performance and comfort when replacing. I have already made a few cosmetic changes and will prolly never stop, seeing as how you can do just about anything and everything to a jeep :)
If you don't want a real high lift.
Go simple
V8 zj springs in front
Rear springs out of a crown Vic. Will for sure give you a inch or so.
With good shocks
Bilsten ome
Put good beefy 32's good luck not a whole lotta money
Decided you want 33's
Put a 1inch bl Mml ( $180)
2 inch bb ($50)
Put 33's have all kinds of fun offroad or on the road with lcg.
But it you are dead set on a big lift old man emu 2 1/2
Or look at dpg offroad good kit rides nice.
Discussion Starter · #12 ·
Go simple
With good shocks
Bilsten ome
2 inch bb ($50)
Thanks drakea
4586shaggy said:
Thanks drakea
If you have any questions about the set up I posted pm me or ask me here I'm happy to help
If you want a quality lift with comfort that means you want to use a lift kit that comes with a softer spring rate(equal or less than OEM factory HD springs which are 140/160lbs. F/R). OME springs have the same spring rates as OEM HD. RC uses a progressive spring that's a bit softer. Pair them up with a shock that can give a compliant ride(regular OME nitrochargers, Rancho 9000's, Monroe Sensatracs etc)and you should be good to go.
Discussion Starter · #15 ·
I was looking at the rc progressive rate springs. The only ones I found were the 2.5" ones. I didn't know if you could match those with a 2" or 3" shock though
Gotta realize the springs "lift" height is generalized. It can be a bit higher or lower depending on vehicle weight etc. You can match those springs up with plenty of shocks. Whats important is knowing the compressed length on em. That way you will know if you need to bumpstop or not. If you want to keep it simple go with OME nitrocharger shocks. Those will match up perfectly with the springs and you will only need a 20mm bumpstop in the back(for spring coil bind)from OME which is part # FK16(15 bucks) and an OME trackbar relocation bracket(another 15-20 bucks).
Discussion Starter · #17 ·
Ok. So I got the rough country 2.5" springs and shocks. JKS adjustable end links. And track bar relocation bracket. Is there anything else I should get to be ready for install? Shouldn't need to do anything with the driveline, should i?
1 - 20 of 265 Posts
