1 - 20 of 60 Posts
i am getting a 4 inch lift kit and SYE for my TJ:punk:, do i need to replace the front driveline or is the stock drive line long enough
now to figure out the best lift to get, i am looking at zone, a brand im not to familiar with them seem to have good reviews, i am also looking at full traction, not very many lifts come with upper control arms, so far for 2000 full traction has the most complete and come with a 3 link set up in the rear or for the same price 4.5" Suspension System by 4Wheel Drive Hardware® for Jeep. i just dont know if 2000 is worth it right now. zone is 500 which would allow me to get the sye and driveline. and still have money left over. but i am sure i will need upper control arms
i have been looking at the re7000 4.5 lift also the bds 4.5 lift comes with shocks, so many choices
going with the RE7000 4.5 lift. i found a deal when i get a advanced adapters SYE and tom woods drive shaft for free, upgraded to adjustable control arms with shocks for about 2000
since i am getting the re7000 4.5 lift i have the choice of bilstien 5100 shock, re monotubes, or old man emu shocks, and thoughts on which is better. also i have read about spring perches in the rear to help re angle the springs to reduce the spring arch, do i need to worry about this?
I love how my Bilstien 5100's ride on my JK. With that said I have a 3.5" Rock Krawler lift on my JK. It came out big, but with an advertised 3.5" it came with spring correction wedges in the rear. The TJ's have even shorter control arms IIRC so your axle would start to angle more with the same amount of lift. I'd look into the spring perches.
Keep in mind I know nothing about the TJ's, just the JK's.
Discussion Starter · #11 ·
thanks i have heard alot about this issue, but i dont really know anyone who has a tj with a tall lift and has used them i just dont wanna spend all this money to find out i need to have more things done
Discussion Starter · #13 ·
Two of our Jeeps have the upper perch moved back into alignment. We actually cut them out and rewelded them to correct the spring angle. Well worth the effort!
does moving the stock perches add to the lift height or does it stay the same
I don't think it adds lift just makes the spring stright up and down. Not at an angle, this helps with alignment, and pinion angle.
Discussion Starter · #15 ·
so sounds like a smart choice is to have some one cut and re weld my upper spring perch when they install my lift kit
i would think it would add to ur lift a little bit. the shortest distances between two points is a streight line. so if u take a line that that is 3 inches long and lay it at and angle, mark the bottom and top points, turn the line streight up and down it will be longer. (hints, A squared + b squared= c squared.... C will never be = to B or C)
Discussion Starter · #18 ·
crappy i dont need more height that just changes everything again
1 - 20 of 60 Posts
