So I have a 2.5 inch rough country lift on my 15 jkur. Its fine. I'm running 315 70 17 duratracs on my stock wheels with 1.5 spacers. I only get rub on full front articulation when I'm turning. Fenders have held up to some serious wheeling over the months but I want more height lol.
So. The lift mish mash I'm thinking of should be alright to do u think but I just wanna make sure I'm not going to burn any churches down.
I want to do the Mopar 4 inch lift that comes with the fox reservoir shocks hi steer fox stabilizer shock and even a front driveshaft! I can pick this up for about 2k on Mopar online parts.
The problem is this lift is a cam bolt lift and only comes with two crappy control arms. I think front upper.
So....enter a full set of metal cloak arms. Around 1200 before shipping... These arms are gorgeous and I really appreciate the engineering that goes into these.
Problem #2. This lift doesn't come with new track bars...ik..probably not necessarily needed. But I wanna fix this for more flex and ride quality.
Enter...metal cloak front and rear track bars. This should give me a pretty good setup I think. And relatively cost effective ish too...
What do you guys think??
Sent from my Nexus 6P using Tapatalk
I'd go with the Superlift front and rear TB's. Dual durometers, adjustable, and priced right (about $100 each).
wouldn't match the other parts lol. All that extra adjustability would probably just cause me to mess it up lol
You should be running steering correction with that much height. With that you have a raised front bracket. You already have a rear axle side TB bracket. You may or may not need TB's with brackets on both ends.
It comes with a Hi steer kit. This isn't enough? Idk
