i have a 2006 tj 6cyl auto with a 2" budget boost and 33x12.50r15 AT. few questions.
everyone knows about front end sag mine is already like that. eventually a will be adding a heavier bumper and a winch. which will make it sag a little more.
1. could I add 1.5" lift springs ie,OME HD springs and keep the 2" spacers?
2. would it be better to just add a 1" body lift (wont help sag but will help clear tires)?
3. or where would I be able to find a HD spring with a 0" lift?
4. on another note, will the stock tire carrier hold a 33"tire?
thanks -Thomas
could you? yes. should you? absolutely not.
a BL is generally considered a requirement to run 33s with less than 4" of lift. and proper bumpstop extensions are a universal requirement.
RockAuto, local auto parts stores, etc. Just have to know what to look for as far as spring rates & lengths
sure, if you modify it and set it up right. plenty of write-ups around.
