4.0 6spd 2005 X
I just ordered some lift parts for the Jeep.
Want to know if I missed anything.
3.5" front and rear coils
Shocks
Front adjustable trac bar
Adjustable rear uppers
Disco's
extended bump stops
Anything else I would need? Would like everyones input, so I do it RIGHT the first time.
Thanks :iamhappy:
Mostly old school..!
You will need either a rear adjustable track bar or a rear track bar relocation bracket. You may also need extended sway bar links for the rear, and extended brake lines (if you plan on wheeling at all). You will most likely find you have some drive line vibes at 3.5" of lift, and will either need to plan on an sye (and related parts), lowering your t-case some, or installing a motor mount lift, or a combination of the last two.
Thanks Dennis,
Can I install a MML without a BL ?
