1 - 20 of 42 Posts
OK, so I'm in the market to level off the unsightly stance that my factory JK Unlimited has and would really prefer to keep the stock aluminum rims and tires....it is a brand new Jeep and I've seen so many stock rims and tires for sale I know I won't get much at all for them.
So, with that said, I'm stuck on whether to buy something like the Daystar Leveling kit (2") or something like the ProComp 2" lift kit that comes with shocks, coils, sway bar, etc.
I know there is a huge difference in price between the two, but I'm also worried about the driving characteristics changing with a lift kit as I've read so many reviews about it changing versus a leveling kit, which everyone seems to say does not affect the ride quality (Highway at speed, etc..).
I guess I should also add that it is a daily driver.... any suggestions?
Thanks in advance!
The Bad Guy
First of all a leveling kit is a lift kit. It just raises the front more than the back. What you are really comparing is a BB (budget boost) versus a coil lift (new springs). The BB adds spacers on top of your stock springs.
Thanks for the clarification,Tom. I assumed as much but was only using the nomenclature that the "market" is using to distinguish the two.
So, would you recommend either the BB or the coil lift?
i'm back
Thanks, everyone. I guess I need to do a lot more research and start talking with other local JK owners more often about their suspension upgrades. Thanks
Before...
http://i1085.photobucket.com/albums/j424/dylanjwhall/002.jpg
After....
http://i1085.photobucket.com/albums/j424/dylanjwhall/011.jpg
I have the 2" AEV spacer kit install went great and my ride quality has not been effected at all. I highly recommend this kit if youre looking for something simple and the "lifted" look and it got rid of factory rake . I plan on getting an actual lift kit when i have the money to go up to 3.5 inches so this is a very good alternative to hold me over :D
Thanks! That is exactly what I am looking to achieve at this point in my JK's life!
No problem :D hope all goes well with your decision and install :thumb:
I have the Teraflex Leveling Kit (pucks, the spring performance version wasn't on the market yet) and for the money I'd say it's unbeatable. Mine is a D.D. and the handling and ride characteristics are virtually the same as stock. I will though in the future upgrade to the Performance Kit (springs) so that my rig will handle additional gear better. Note that I'm never going to go bigger than a 33" tire, which is what I have. Best way to determine what size lift to get is by what size tire you want to run.
Have fun!:)
I went the BB route with mine and was very happy with the results. Mine is also a dd, and random forest/fire roads are about as hardcore as my Jeep ever sees. For the price, the extra $$$ may be better spent on tires/wheels. Do your homework and ask lots of questions- shopping your lift is part of your modding journey- enjoy it!
Congrats on the Jeep!
I took delivery about a month ago, and immediately bought the ReadyLIFT leveling kit. You have your choice of picking the front end up 1/2 inch, 1 inch or 1.5 inches with the aluminum spacers in the kit.
I traded out the stock 18" Bridgestone Duelers and wheels for 285 70 17 Goodyear Duratracs on AEV Pintlers.
We used the ReadyLIFT kit ($260) to raise the front one inch. This resulted in a leveled Jeep and plenty of clearance for the tires with no rubbing, and the wheels are made for Jeeps, so no spacers were required.
The GY tires are about an inch taller than the Bridgestones, so we wound up picking the whole thing up one inch with the tires all around, and an additional inch in the front with the spacer kit. The ride height is perfect for what I wanted.
Net result: You can go as high as you want, but if you want to level it, you only have to pick up the front about one inch. The ride is factory perfect, and we gave up nothing in terms of ride/stability/safety.
+1 I also went with the Teraflex leveling kit and I love it. Price was right, makes the Jeep look a ton better and the ride quality is as good or better. Mine is a DD and I'll be going to 33's soon but don't plan to go any bigger.
Be sure to read the stickie on "Death wobble" and be sure to not only tighten up all the new stuff to spec, but loosen the trackbar and LCA bolts too so you can shake it all up and re-tourque under load.
Also, the kit I got came with greasable sway bar links so you want to be sure to shoot some grease in them once installed and after you have put a few miles on it. The stock sway bar links are a one piece housing....but make up your mind and you'll see what I mean!
Congrats on the new Jeep. I'm loving mine!:punk:
Have fun!:)
Add me to the list of guys with the spacer Teraflex leveling kit as well. I went with it for several reasons:
1 - It looks just fine with stock tires, which I have had to run for a while
2 - It will fit 33s with no problem
3 - It was cheap! $115 shipped to my door
4 - Simple to install. I did it in 1.5 hours without ever taking a wheel off the Jeep.
5 - When I undoubtedly decided to upgrade, I can probably sell the kit for probably 75% of the purchase price.
I have just ordered new 15" Trackers and 33" Duratracs, so it will look much better, but it truly looks fine with the stockers too. Don't have a great pic, but this should give you an idea.
I went 2" in the front, 1" in the back, $75
Discussion Starter · #18 ·
Thank you, all, for all the great advice! I've been calling around to some local 4x4 shops about leveling my Jeep (2011 JK Unlimited) and one shop recommend a 2" lift in the front, only. I've seen some other kits and all include a 1" lift in the rear, as well as the 2" in the front. Is this acceptable practice; only doing the 2" in the front? PS - the lift will also include new shocks (front only)....advice please
IMO, if you do just the 2" lift in the front, the front will be higher than the rear. Mine sites pretty much dead level with the 2" front and 1" rear spacers that come with the TF kit. If you aren't wanting much lift and only want to level, just put a 1" spacer in the front and call it a day. And do it yourself. Don't pay a shop.
This ^
1 - 20 of 42 Posts
