I am purchasing a lift for my wrangler I don't want to have to mess around with the transfer case too much. How much of a difference will the 3.75" and 4" lift make? Will it be that much higher with a 4" lift on it?
if you follow the advice of the previous poster then be prepared to have vibes and start saving for a SYE and driveshaft
Go with the zone 4.25" kit...a 1.25" body lift has no negative. Also, if you ever plan to use a tummy tuck then a body lift will assist with that. The zone kit also allows you to not use a tcase drop in most cases
