Hi....if I want to do a 2 inch lift on my 2002 TJ will I need to change shocks or anything else?......TYIA
Depends on the mileage. My stock springs had zero sagging at 130,000 miles. My shocks were shot. Coil springs if they're sagging (12" front/8" rear coil length as it sits is stock height and longer shocks at a minimum. You could do 2" budget boost spacers ($80 all 4) and nothing else if it's for street use only and you don't want a Caddy ride. A much cheaper option is a 1.25" body lift for $95 and an hour of your time. Nothing else needed for 3/4" less lift and it doesn't effect your ride quality.
