Need some help when I got my jeep light bar was already installed one of the lights went out and I wanted to take it off and replace (figured out later that you could replace bulb) the wires connecting the light don't seem to have some sort of quick disconnect is this normal.
Vendor
Most lights will have some sort of connector where it attaches to the wiring harness so that you can take the light off should you need to do so. If your lights are hard wired into the harness you can cut the wiring and add a weather proof connector for future maintenance. Let me know if you have any questions!
-Ryan
