Hello,
I have a 2005 JK Wrangler X. I replaced the worn sound bar speakers and now my sound bar dome lights do not work. They did flash on/off a couple of times then nothing. I pulled the speakers back out and reversed the + / - and re-installed the speakers and still nothing. When I open the door the cab lights under the dash do come on. When I use the manual switch on the blinker arm the under cab lights come on but not the sound bar lights. I tested all fuses I could locate behind the glove box and under the engine hood and all tested fine.
Any ideas? Brian
I would guess that you accidentally disconnected or broke a wire to the lights when you were messing with the speakers.
They are completely separate wires, but they are probably loomed/ tied together inside the bar.
