Passed a buddy and he told me I had a drivers taillight out. So I replaced with a spare and still doesn't work. Switched the bulb I thought was bad with the passenger side. Passenger still works driver side still not. Light works as brake light and turn signal just not with headlights. Now the real kicker. Everything above applies to the driver side marker also. No clue here.
Check for power on the WHT/ORG wire at the tail light. (lights on of course)
If no power, check fuse M17 (15A)
Beyond that, it would be tracing wires to see where the break occurs or testing the TIPM.
Figured it out about an hour before this post. It was the fuse though. Thank you for the help.
I appreciate the bump above also.
