Limp mode on a manual
20573 Views 60 Replies 11 Participants Last post by  WillysGal
I was driving on an easy trail earlier today, but hit a bump or rut with some force. The jeep made a jeep, the ESC Malfunction and MIL Lights illuminated, and limp mode was enabled, or what I believe to be limp mode: power drops off in all gears at 3k.
I am going to the dealer tomorrow; just happened to have an appointment.
Any thoughts on what is going on.
My limited searching resulted in auto transmission limps.
I doubt there is any causal relationship, but:
1) Earlier today I pulled out a stuck F150. Low 1st easy pull, no jerking or other "violence."
2) Saturday I got stuck in sand down to the frame, and needed to be pulled out with a winch.
21 - 40 of 61 Posts
No problem sir!
A loose batt terminal can cause ALL sorts of bizzare problems in any vehicle. I'm willing to bet that is the issue, as typically the simplest solution is usually the right one. But there very well could be a faulty plug, a loose ground, or a million other manufacturing defects that could have happened during assembly.
I would def, still have it given the once over by a service shop and tell them the details of the problem, how you resolved it, and why you feel it is electrical in nature. Then hopefully someone more familiar with the wiring of the engine can ensure that everything is buttoned up properly, since it is under warranty.
Good luck. Let us know how it turns out.
This morning, I went and double checked the battery terminals. I opted not to dig into the grounds as frankly I was intimidated by the degree of work necessary to reach that part of the engine.
Went for a drive on the same offending road as yesterday. After about 4 miles of washboard, the CEL and ESC lights came on again. Engine rpm drop again at 3k.
The "key dance" does not display any code. Tried a couple of sequences.
I suppose on the bright side I eliminated the battery terminals as a causal factor. I did check that they were still tight.
I have not reset the computer, and am not sure if I should. If I do, will I lose the history of the CEL events?
I have a service appointment scheduled for 7/18/14.
Hope this all works out for you, I know how frustrating these issues can be. And as always keep us posted.
Thank you for the kind words.
Certainly shall do on updates.
Yeah don't clear it this time. Hopefully they will delve further than simply replacing a cam sensor that is probably fine.
Got it.
Thank you again for all your help!
Got it.
No problem, sorry it wasn't much help. Hopefully it gets taken care of.
Some weirdness:
So, I start up the jeep this morning. CEL light on, but ESC is off. The jeep exhibited this during the first occurrence. On engine start, only CEL displays, and the ESC will illuminate at some point later, seemingly after a jar or bump in the road.
Anyhow, drive to the gym, and about an hour later, I start the jeep again, and no CEL display.
This has not happened before. That is, once active the CEL stayed illuminated at all times.
Updates:
1. All error lamps have been off since my last post above.
2. I went to the dealer today, and they could not find any problems at all. They read the codes, but tell me that components checked out ok. They also told me that they checked grounds and the wheel position sensor.
3. I had a long, but not confrontational, discussion with my service advisor. He seems sympathetic to the problem, and I prefer not to poison my relationship with him. Anyhow, next step is to see if the error lamps display again, and then leave the jeep for an extended period.
4. Driving home, I (of course) drove down the gravel road (referenced above), and of course, no error lamps.
I am thinking that my next action will be to take a local easy trail this weekend, and see if that will trigger the problem.
Update:
3.5 miles down an easy trail and I am back to square one ... :(
No code was displayed when I did the key dance.
I will try to get in to the dealer tomorrow or Tuesday.
Sorry you are having such issues. This would drive me crazy.
I'm still convinced of a loose connection.
Thanks; and, yes, this is making me a bit bonkers.
BTW, this afternoon, all error lamps are off again.
The intermittent nature of this problem concerns me. Will the dealer simply do another cursory check, and say it's okay. Doubt that the dealer will actually bother to take it on a dirt road, and then if they do, the problem may not occur. I suppose lemon-law criteria is my leverage to convince the dealer not shrug this off. But, this is becoming a PITA.
See if one of the service guys will go with u to recreate the problem?
Thanks; and, yes, this is making me a bit bonkers. BTW, this afternoon, all error lamps are off again. The intermittent nature of this problem concerns me. Will the dealer simply do another cursory check, and say it's okay. Doubt that the dealer will actually bother to take it on a dirt road, and then if they do, the problem may not occur. I suppose lemon-law criteria is my leverage to convince the dealer not shrug this off. But, this is becoming a PITA.
Jeez, that is so strange. Are you taking pictures when the CEL is on? If not, start so you at least have some evidence if you end up wanting to pursue a lemon case. It does seem like something must be loose. Sorry you're still dealing with this!
Jeez, that is so strange. Are you taking pictures when the CEL is on? If not. Start so you at least have some evidence if you end up wanting to pursue a lemon case. It does seem like something must be loose. Sorry you're still dealing with this!
Great idea! Maybe even setup a video camera to record the dash while you're driving over the area where you experience it.
That may work. Good idea. Thanks!
My wife suggested the same. Great minds ... :)
Another good idea. Good project for my 11 yo. Thanks!
Jeep is at the dealer.
Dealer confirmed that they can read codes that seem to "self clear".
Dealer provided me with a loaner, which they did not have to do. So, I have to commend that.
Jeep is at the dealer. Dealer confirmed that they can read codes that seem to "self clear". Dealer provided me with a loaner, which they did not have to do. So, I have to commend that.
Hope they figure it out and it's an easy fix!
Much appreciated!
Just got a call from my dealer, and they replaced the cam position sensor again.
The service advisor agreed with my skepticism that two cam position sensors from two different sources (factory and dealer) would both be bad, so they will keep the jeep for a more thorough test on rutted washboard type road, assuming they can find one close by ... which, this being Phoenix should not be too hard, I hope.
Much appreciated!
Dude, sounds like they are treating you right!
Much appreciated! ********************* Just got a call from my dealer, and they replaced the cam position sensor again. The service advisor agreed with my skepticism that two cam position sensors from two different sources (factory and dealer) would both be bad, so they will keep the jeep for a more thorough test on rutted washboard type road, assuming they can find one close by ... which, this being Phoenix should not be too hard, I hope.
That would be quite a fluke unless something is making the sensor go bad....if that's even possible.
21 - 40 of 61 Posts
