If you are going to run without the carpet I would go with Line-X because it is quality. It will last is always thicker and better looking than anything I have seen from the DIY kits. You'll have to pull everything out but if it is not your daily driver it will be worth the effort in the long run.
If you go the DIY route then proper prep is key.
