Dayum! That's some work.
A best friend to help with the work, two complete weekends with little to no sleep, 4 long weekdays, and one unhappy woman!Dayum! That's some work.
I do have a set of rocker guards to install there, but that shouldn't impact the clearance to much. I'll have to measure it when I get home later and get back to you!Bought the softtop version of your rig 4 weeks ago. Looking at doing some of the same mods as you, just can't do them quite as quickly. Really like the tummy tuck idea. What is your clearance under the door from the bottom of the body to the ground? Looks good!
Thanks! Right now with 35's mine is running right at 25" with a 9/16" gap between the panel and the bottom of the guards. I like your setup, gives me some good ideas for improvements to work towards. Let us know how it performs!Bottom of rocker panel to the ground measures 24".
Will do! I'm tweaking suspension now (i.e. rear pinion angle, bumpstop, track bar, etc.), before taking it in for alignment. I had some binding and handling issues with the crappy sway bar disconnects I had. Turns out, since they weren't adjustable, that there was way to much angle on the front sway bar. I purchased and installed a new JKS adjustable set this weekend, set the sway bar angle to 10 degrees, then loosened and re-tightened all my suspension components. This made a huge difference in the ride. I'm still not completely happy with it, but a Currie or MC lift kit is planned for the future. Since the BDS kit was a freebie from a buddy, it will work for now and I won't complain.Thanks! Right now with 35's mine is running right at 25" with a 9/16" gap between the panel and the bottom of the guards. I like your setup, gives me some good ideas for improvements to work towards. Let us know how it performs!
