I requested my build sheet yesterday from HQ and received it today (2006 LJ). I knew I was equipped with D30 front and D44 rear, but I was very pleased to find I have Trac-Lok rear diff (LSD). Here's a peak at the goods.
What are your opinions of Trac-Lok?
DEH 6-Speed Manual NSG370 Transmission
DHNS Command-Trac Part Time 4WD System
DJJS Dana 30/186MM Front Axle
DMES 3.73 Rear Axle Ratio
DRKS Heavy Duty Dana 44 Rear Axle
DSAS Trac-Lok Differential Rear Axle
Trac-Lok was standard on your LJ. (Everything listed above was standard)
It's just ok. The clutch packs will wear out over time(if they haven't already), then it's just the same as an open diff
Trac-Lok is better than an open diff. Barely.
