1 - 15 of 15 Posts
Very nice. Im a fan. Here is what it looks like with a 2'' lift and 35's.
The dana 44's will handle 35's, but am not sure if you have to upgrade your axels to run 37's.:confused:
Good lookin Jeep:thumb:...I want the metal Cloak fenders, but can't afford them right now.:(
Jeeponator
Did either of you cut the rear fenders or just bolt on the MC's?
I can get behind this thread! Here is mine at MoparPalooza this weekend- Metalcloaks front/rear, AEV tummy tuck, no lift, 35's...
Do you guys have any tire rubbing issues?
Flash
I added 1" bumpstop extensions front and rear. I have no issues with rubbing because of flex, but I need to add wheels spacers so I can go full lock without rubbing my front swaybar... or just put on an anti-rock :D
Discussion Starter #12
Flash
I had rubbing on the stock sway bar. I tried two washers on the steering stops and still had rubbing.
I took off the sterring stop washers and added a 4" lift with the Anti-Rock sway bar. Rubbing is gone now.
_
Man that thing look awesome with that soft top.
Any flatground side shots of your LJ?
Yeah I'd like to see that too.
I've got an LJ that I'd like to run larger tires but don't want much lift.
ltdanyj I found pics of your jeep while looking for some steel rims for my unlimited. May i ask what backspacing you're running? I've been told 3.5 to 4 would be enough to prevent rubbing.
1 - 15 of 15 Posts
