I can not lock or unlock doors using the the driver's side button or passenger inside. The key fob works though. Twice today i tired to unlock the door for my kid and I had to reach over and pull the lever to unlock.
Could it be a fuse, even though the key fob works?
Can you lock from the passenger side button?
Yes, just the passer side works. Driver's side does not.
Would this be covered under the extended warranty?
Or is it a cheap easy fix?
It's most likely a warranty issue (loose door plug or similar)
Thanks. Would be a bad switch? $30 under eBay and easier than dealer, rental, etc.
It works sometimes. Just got it to work twice and then it did not. Key fob works perfectly.
Anything is possible. Use a meter and check the switch for continuity in each position.
Discussion Starter #7
Thanks. Need to figure out the one I bought for my Alpine stereo. 2 months and still cant figure out how to use, LOL
WF approved Offical Jeep Account.
Hi DIRT BOY,
Sorry to hear you are experiencing this. We suggest having your dealer inspect this concern if you have not done so already, as they will be in the best position to assist. We are also available via private message if you would like any additional assistance during that process.
Mark
Jeep Social Care Specialist
