Im stuck which style of locker would you guys recommend, air or electronic? i live in wisconsin it snows and ices here so its one of the two, just not sure which way to go
I definitely can't agree Ox Lockers have less moving parts or work flawlessly. If they were both of those, they would be far more popular with builders than they are.Neither. I recommend ox lockers. They're cable actuated and have less moving parts. They work flawlessly and the cover they come with looks pretty cool too
Which ones? The aftermarket ones, that I am aware of, don't truly lock but, are glorified limited slip, instead. Admittedly, I do not keep up with them because, the couple that run them in my club, never seem to have them functioning, as advertised.well there my winter project basicly, how are the electronic lockers tho?
I'm using a small ARB compressor for the locker and a Viair 400p for tires.what kind of compressor are you guys running with your arb lockers?
You're describing the Auburn ECTED which is clutch-based and a combination of an LSD and a (barely) locker. I personally wouldn't touch or even consider an ECTED.The aftermarket ones, that I am aware of, don't truly lock but, are glorified limited slip, instead.
ARB's locker/compressor kits provide the correct size air hose needed to install them.allright guess it will be air lockers, what size tubing to those use, havent had a chance to read up on them to much?
