I'm looking at the RE 4.5in lift kit w/ 33" mud terrains. Are there any long term or even short term problems I should know about? Anything at all...
I'd be weary of the Dana 35. You are border line with 33s but it is easy to grenade that turd.d35 rear d30 front 6spd manual tranny 4.0L inline 6
How would I grenade that turd? I'll probably be installing 4:56 gearsI'd be weary of the Dana 35. You are border line with 33s but it is easy to grenade that turd.
Yes I know that. What I need to know is if the set up I'm looking at is that proper set up.A properly set up wrangler should drive as well or better than a stock jeep.![]()
Thanks for the heads up. If I blow out the rear, I'll have a good excuse to upgrade.gears have nothing to do with the amount of stress put ont he axle to turn the bigger heavier wheels
I always say upgrade before you break. :wavey:Thanks for the heads up. If I blow out the rear, I'll have a good excuse to upgrade.![]()
I'd say ring and pinion or spider gears but those usually take something else with it. If you want my honest opinion you better ask someone else on an acceptable replacement axle.Is it just the axle or the whole thing? What kind should I get to avoid that problem?
