1 - 10 of 10 Posts
I just posted one thread on this, but I've run into a new problem - I pulled the first plug - it was an NGK. I go to replace it with a Champion 7034 (I have a 2003 TJ Sport), and the Champion plug is longer than the NGK - so much longer, in fact, that my spark plug socket can't even get to the part of the plug with the nut.
Do I:
1. Get different plugs?
2. Get a longer socket?
Is the threaded length the same? Also what is the number on the NGK?
Champion RC12ECC - I used these in my '02. They seem to work perfectly and are the OEM recommended plug.
BTW I've tried lots of plugs over the years but in my opinion the ones that perform best and last much longer have been Champion 4412 Truck Plugs.
Get a longer socket. The plugs you are putting in are applicable for your jeep and most others will be the longer style too. The threaded part is the critical part.
Everything I said applies to my 99 so since yours is newer and is distributorless, there are other factors involved. Go with OEM and you can't go wrong.
I try to go OEM for everything. This way it's guaranteed to fit.
Knows a couple things...
The Champion 7034 spark plug is the correct model spark plug. In fact, it is a superb spark plug for 2000 and newer 4.0L engines. Try a different spark plug socket.
1 - 10 of 10 Posts
