I have a 90 yj with the 4.2. I took the dash trim off the other day to clean it out and noticed that the control panel heat cool lever would
Slightly move toward the middle. It would not stay on the warm. I looked behind the dash and could see the pulley cable bolt head had snapped off. I am going to upload a picture so you can see. I am having trouble getting the bolt out now to replace it but there seems to be enough space to screw in a smaller one on top of where it broke out. I can’t find any info on that bolt size. Any ideas or suggestions? You can see the left one clearly is fine but just off the image you can see the right one is off. That little screw/bolt in that eyelet is the size i’m Looking for.
Thanks in advance.
Jeremy
Maybe you can remove and match the good one.
It's not a bolt, it's a plastic pin.... it's held on by the push on retainer
